Spinner18
whats a good clutch set-up to i can take XCR's, REV's and whatnot? Lake and trail riding.
blueflash
51/43 helix..
8dn-20 weights 4.5g both holes
WWW primary spring
Green or Red secondary spring
Your sled already has those weights so all you need is the right rivets put in them, helix and the springs
I just did this to my sled and the difference is amazing. At 70-80mph it will pull hard and leave those stock sleds behind.
WWW primary spring
Spinner18
roughly how much with it cost me for thes clutch parts? Thanks
Rambunctious
helix is stock from RX1 - $30used to $45 new
rivets - about 30 cents each
primary spring - $18?
this is a cheap setup , i used it with my stock red secondary and beat 3 rev800ho's and a piped 700 x Edge polaris.
Ramb
Ramb
Rambunctious
the theory is you are adding weight ( replacing 3.1 grams rivets with 4.5 gram rivets) to make the clutch shift faster, because the srx has the Hp to do it and keep accelerating.
the WWW spring raises the engagement rpm (4200) for a good launch (assuming you have good traction)
bottom line, you want to pull at 8300 for 98-99 srx, 8500 for 2000+srx
Ramb
Ramb
jamesfiii800
is this setup for a 98 aswell?
jamesfiii800
if i pull my clutch apart and take pics can you guys tell me if its stock?
Probably with just part #"s and spring colors, most everyone here knows this stuff really good. A good cleaning does wonders too.
blueflash
go to the tech page and it will tell you what your sled comes with in its clutch stock. Theres little colour markings on your springs that will tell you what it is.
deekersrx700
works good
Lets not forget thanks to Mrviper, this is his recommended setup!!
I used this setup on the weekend and ran 115.6 in 2000 feet in +5 degree celsius weather, good enough for first in 700 trail imp in North Bay.
blueflash said:51/43 helix..
WWW primary spring
Green secondary spring
What are you running your secondary at and I can't seem to find a part number for a www spring, do you have the number?
jminor1 said:What are you running your secondary at and I can't seem to find a part number for a www spring, do you have the number?
http://www.totallyamaha.com/snowmobiles/aaTECH/drivespecs/primary_springs.htm
90501-583L1-00 Long spring
Thanks for your help! Still looking for the degree on the secondary and also the 51\43 helix.
Rambunctious
try 2000srx ( bruce from CBPerformance) for the helix
I understand the 51/43 is a stock helix for RX1, and I bought one from him.
I have my red stock spring wound to 70 deg with the 51/43 helix
8500-8550 rpm on top end.
Ramb
Ramb
