how does everybody "strap down" their susp.?
If your serious about it you take the shocks apart and have spacers installed on top of the piston so the shaft travel is limited. Other wise you back off the spring and run a piece of chain from one shock bolt to the other to limit the travel. ===SRXSRULE===
