94 vmax 600 oil line change question?
hereismylife
Pa
Website
www.hereismylife.com
ok here is what I am tring to figure out.Why did they change this? My 94 oil line goes to the front of the carbs and my 97 goes to the fuel pump. They look like the same fuel pump but that does not mean much.
I was wondering can i put the 94 line to the fuel pump without having any problems.
thanks joe
maybe ithis is what I have ?????
Direct OIl Injection Kits
Racing's oil injection kits synchronize the amount of oil used with the throttle position by injecting oil directly into the intake tract instead of into the fuel pump as with the stock system. Our oil injection system ensures more consistent performance, less plug fouling and more forgiving jetting than with the stock set-up. Other, cheaper systems inject oil into the fuel line. Don't be fooled, this method is not direct oil injection and will not correct the lag time before the oil mixes with the fuel remaining in the float bowls. Don't compromise.
later joe
later joe
That must be the deal joe because our '94's are all stock and the line
goes to the FP where it's then mixed.
