1 1/4 iceripper
Lugs will rub on the heat exchanger protectors. Some say to just let it rub itself down. I highly recommend clipping the ends that rub. I lost nearly 10 mph because of the rub. With the right tool, you can clip it in 10 minutes. Others will say to change 8 tooth. I wouldn't. You can do a search under my screen name and find info about clipping and more detailed discussions about this topic.
Good Luck
