Track hits inside of suspension
stealth800
Rochester NY
I noticed on my 04 Viper S that the upper mount for the rear shock is very close to the track, appears to hit at times. This is the part of the track where it bends at the rear upper idler wheels. The inside of the track has a slight rub mark right down the middle, I can't even stick my finger between the track and the shock mount. The wheels are ok , is this normal? Thanks.
I,m pretty sure its normal its the same on my viper it doesn't look like there is a space there but there is, very small had the same rub mark on my track and no problems.
Thanks for the replys, I feel better about it now.I also got to looked at my buddies SRX and it is the same way too. You'd think they would have designed it with a little more room. I just installed a new track and that closeness between the track and the suspension made me nervous.
