Viper Slide Rail Question
151Viper
Larimore, ND
I have a 02 Viper short track with a 151 hartman extension kit on it so it is relocated back and has some pretty long extensions on it. I would like to get rid of the rail extensions all together and buy different rails. Does anyone know what else I would have to replace to put rx-1 mountain rails on for example? Has anyone else attempted anything like this with swaping 121 skid parts into longer rails?
need
you can use the W arm but you will loose some wheels' will definately need the lower front shock brkt, the two L brackets the W or H arm bolts to on the 141 rails, limiter straps, transfer rods or straps, drop brackets, move entire skid back 9 1/4 inches
Hey bud you should have bought that skid..Larry updated it and WOOOOWWW what a great ride..I can FLY over the big bumps and it weighs 49.5 lbs on a digital scale....we should hook up and ride sometime....Do you ever ride owls head or revy????Terry :yrules:
Larry's skid
Yes, maybe I should have cause I ended up with a 76 lb M10 W that I had a lot of problems setting up. I also know that 10.5 inches of M 10 isn't going to work in 2 foot ugly spaced chunkers we have getting to the mountains.The trails around here are war zones for the young guys not me. I Have been to Owls Head over to Hunters and Eagle to the Mine site but health has been a limiting factor. Maybe next year. Ride Safe and have a good year Terry! By the way is Larry still operating, and if you know his number that would be outstanding.
Gil
