fully clipped 1.25 Ripsaw or every 3rd?
Yamaouch08
North Branch,Michigan
I was wondering what track would be better a fully cliped one or a clip on every 3rd? is there any advantage to either one? Any feedback would be helpfull. thanks
Every third is lighter, but you can't run extrovert drivers unless you punch the holes. Fully clipped is a little bit heavier but allows you to run extroverts. Fully clipped is also a little better in low snow conditions, plastic on rubber doesn't slide very well. If you aren't planning on running extroverts, go with the every third.
