97 XTC Clutching issues.
Upnorthguy00
Franklin, WI
I am haveing some problems with the clutching on my XTC 600 twin. I just put on twin Power INC pipes, had the carbs and clutches set up. Sled also has thin head gasket and carbon fiber reeds. It takes off great and revs up to like 8200. Then if you hold it wide open for a while (accrost the lake)the RPM's will drop back to like 7000. Seems like it is over shifting. Like its going into over drive then looseing all its go. What kind of set up should I be running in this sled??? What would cause this problem?
Thanks Ryan
