Primary engagement shims?
Sno-Xr
Clio,MI
Primary engagement shims? TURK??
I want to bring my engagement up a little but dont want to affect the rest of the shift-out. Its shifting out perfect now. Will the engagement shims afffect shift-out, and how much?
The shims will raise engagement by about 100 rpm per shim. The spring has a constant rate which means in turn that you should pull 100 rpm higher throughout the shift per shim.
Thanks, wasn't sure if it would raise the R's all the way through , but kind of thought it would.I really dont want to raise the shift-out(8600), any sugestions to get the engagement(200-300) up without raising shift-out would be great.
