mulderdad
I spun three out of the four drivers on my 98 srx7.
Has anyone else had this happen to them? How big of a job is it to change them? I know they are pressed on the hex shaft with a press so i'm just going to change the whole thing. Maybe a new track while i'm at it.
Anything else I should replace while I have it all ripped apart?
Thanks,
mul
Thanks,
mul
just curious but what make you think the drivers are spun???
mulderdad
When I turned my sled on its side, the only driver that turns is the right one. Also, I can see the plastic center drivers are stripped and the shaft just spins inside them.
How well do anti-ratchet drivers work?
mul
mul
anti rachet drivers really work well. Pressing the new driver are fairly easy if you have a arbor or hydraulic press.
