clutching jetting critics
high country
spokane
00' mm700 141 yoko, me 225lbs, psi ceramic pipes end dump, peak head @21cc, mild porting, gutted air box, reed spacers, stock gearing Ithink, my tach is busted so can I get a critics opinon of the setup. I just bought the sled.
primary: y w y with 1 shim, 8dn20 w/steel rivet @ tip, open inner,
secondary: mpi roller w/ 48/40 helix with wh/blue @70*
belt: 8dn
jetting: mains 143.8 x3 pilots 45 x3 fuel screw @2 1/4 out
I ride @ 3500-7000ft mostly boodockin' but I like to burn on the way in and climb what gets put in front of me.
I have yet to put this thing on snow so I could use a bit of advice on the setup I bought it as a basket case so I am nervous and I need to get the tach working to verify my settings but I know some of you can tell me if I am in the ball park or not. and maybe a guess on the ponies shes puttin' down. thanks!
