jamesfiii800
im looking for some good clutching to run 660ft on ice/grass thanks james
ps i believe its all stock right now ywy primary black w/red mark on the secondary and the helix says 70
8BU-00's with 4.5 grams in the tip, stock primary spring with 4mm's of shims for ice (bender orange with 12mm's of shims for grass), 51/43 helix with silver secondary spring set at 70. 20/39 gearing
blueflash
what gearing??
yamaholic22
21/40 or 22/40 or so i would say
bluehammer
Gearing like he said above.tomseal6 said:8BU-00's with 4.5 grams in the tip, stock primary spring with 4mm's of shims for ice (bender orange with 12mm's of shims for grass), 51/43 helix with silver secondary spring set at 70. 20/39 gearing
