ReaperSRX
I picked up a Max Perf wide for my SRX any after reading instructions i think i might bit off more than i can chew! first how do i get the control arms off, i have a skid plate, does it have to come off.....Reaper
best to pull the skid plate so you can get to the jamb nuts on the Radius rods....
ReaperSRX
Will all work involving the radius rods be done from under the machine or do you acess the bolts from inside under the pipes?, will have to remove the pipes anyway to change the steering rods.........Reaper
Most of the work is done from the outside.....
