rear wheel bearing part numbers
nhsrx701
does any one know the number on the bearing for the rear wheels in the suspension. Yamaha is only listing the wheel/bearing assembly and I want to just replace the bearings.
For the 97 vmax 800 its listing 93306-20469-00 as a bearing number. Is it the same bearing.
I was going to go to the local bearing dealer in manchester to buy some. If anyone knows the number that is stamped on the bearing that would be great. Also if you know if the yami 93306-20469-00 can be used, that would work too. the stock bearing has been in there for 8000+ miles and its time for some prevenative maintainance......thanks
that would be the wheels located at the very rear of the suspension...thanks
The bearing industry # for these are 6204-2RS
The 2RS stands for 2/ Rubber/ seals.
The smaller wheels have smaller bearings. # 6004-2RS
