ccrider
Rookie mistake - need some help.
I took my secondary apart to change the helix and add a shim.....after I got it apart I realized that there are balance holes cut in the outer rim of both halves of the secondary.
My question is this....
How do you assemble the clutch back together properly so that it is in the proper alignment????
ccrider
Someone has got to know this.....
Any chance I can get one of you to take a look at your sled to answer this?
Thanks.
Thanks.
dustin
i did the same with my viper and thought i was screwed but i just but the balance holes as close to across from one another as i could and i hvent had any problems
ccrider
Went to the dealer last night and they told me that there is no orientation....each sheave is balanced individually and they can go back together in all 3 positions.
