center shock upside down.
max
I bought a new öhlins center shock,had it upside down for 200 km.I wonder if anything can happen to the shock if its upside down? thanks
well
they are non directional shocks. Which way did you have it, for some reason I think mine stated to mount it upside down. maxdlx
The position of the shock does not matter in the pro action rear skid. I have run mine upside down, down side up...no probs!!!!
hey
If it is rebound adj you need it with the body up, and the adj end down, or you will break the adj off the shaft. Maxdlx
