srxburns
I have been reading that some people recommend using at 51/43 RX1 helix. Can you use this without changes to the stock primary. What Spring color and twist would be the best? Can I use stock Red secondary spring?
You are probably & allmost definately overrev with the stock primary spring & weights loaded up. I like the w-w-w primary spring. The red at 80 wrap in the secondary is OK but I kinda prefer the green at 60 for better downshift.
srxburns
Thanks for you help, I will give it a shot.
