ccrider
Anybody have any recommendations for Thunder Shift arm weight set-ups for a 98 SRX 600? I am looking for an agressive trail set-up.
The sled was previously set up for drag and doesn't backshift worth a shit. It comes hard right off the line to about 8400rpm and will pull all the way to the top....but can only hit ~7200rpm if I let off and get back on it. Right now, it has 2 brass weights in the middle and tip....not sure on the actual weight of them. The arms I believe is a 39.66g arm. I have a gwg primary spring, g secondary. I'm still unsure about my helix b/c the guy who owned it before me ground off the identification for the helix (probably a cheater)....it is aftermarket and annodized blue, but I have no idea what it is.
Any help in getting this thing back to a trailable version would be great.
Thanks.
ALSO! LOOKING FOR SOME THUNDER SHIFT TUNING WEIGHTS IF YOU HAVE THEM....
Thanks.
ccrider
Anyone????
vipertripplexxx
Check your power valves and see if some are stuck open.
ccrider
I already checked the PV's.....they slide like butter.
