DanQ
Sometimes when I start my 02 viper the oil light comes on. it might stay on for 30 sec to a minute then it goes out. The oil tank is full. It doesn't happen on every restart, only once and awhile. It never comes on again after it as gone out.
Ideas on why this is happening? bad level sensor? I've already armored the wire harness under the engine so I don't think it is a rub thru.
yamaholic22
as long as it goes out and comes on when the oil is low i wouldn't really worry about it, but that is just me. You could always try a new oil level sensor, i believe they are pretty cheap.
Densrx
- May 19, 2003
bad oil sensor
the 02 sled had oil sensor problem..there s a good chance it s not good
DanQ
update: replaced the oil sensor. the light is still on. next theory?
DanQ
Just thought I'd followup now that I've had time to fix this. Turns out the wire harness was rubbing on the mag side carb fuel hose clamp and shorted the oil sensor wire out. When I added shielding to the under engine harness I didn't cover up that high.. Anyway it is fixed now.
One interesting thing. the oil level sensor reads "open" on the low ohms scale either in or out of oil. I wonder how those things work?
Dan
Dan
