ReaperSRX
After doing a pre-trip check last night i found that 2 PV are half way pulled through and the middle cable i frayed, i guess that is not bad with over 9500kms on the old SRX. I have three new PVs and cable on the way. My question is on replacing the cable, it looks straight foward but is there anything i should be aware of......just take the 2 allen screws out of the front and take apart and replace cable.........James
yamaholic22
yup it is really pretty easy to do. Just make sure that you get the cables back in the right spots on the servo, because they pull from different distances. If you aren't sure how the valve housing goes back together (spring and retainer) just take a look at the parts fiche on yamaha's site.
ReaperSRX
I have checked out the parts view, i am only changing one cable so mixing up wont be a problem. Glad i checked these out before i went on my 800km/500mile trip this weekend. I am pretty sure that at least one of the PV would have pulled through all the way out............thanks..........James
