SRX track clips
01&02SRX
Grafton Mass
What exactly is the deal or the train of thought on track clips regarding pros and cons a lot of new tracks have every third window clipped as opposed to eryone Good? or Bad? ;)! :yrules:
Tracks that have every window clipped allow you to use extrovert drivers (which drive off the rubber lugs the same as regular drivers do, but also drive on the track windows), which greatly reduces ratcheting, allowing you to run your track looser, so there is less friction and more track h.p. The downside to every window clipped is that they are heavier than every third window clipped tracks. If you don't plan on running extrovert drivers i recommend every third clipped for their lighter weight.
I like to think iI am pretty smart when it comes to sleds but this is going on my 01 srx what drivers do I have they are stock and what exactly is an extroverted driver Thanks
stock drivers (like the ones that came in your srx) just drive off of the rubber lugs on the inside of the track belt. Extrovert drivers drive off those lugs PLUS they have teeth that drive off the track windows (the open holes in the track).
