Skis
norwegian
Well-known member
norway
Will skis from a 2001 mm fit on a 97 venture 500 liquid cooled? I haven't got the rubber pads for it, how will the installation go then?
Like Rich said it will work,,and for the rubber stops order ones for
a 2002 srx,,"S" blocks,, they'll put more back pressure on the ski reducing
darting.
Yamahammer485 said:
You can use the regular rubber pads, and if im not mistaken feature a "J" on them. If they dont fit, then you can always put the old ones back on.
Never seen a J pad before,, if he uses the s pads it'll help his skis out
just put them on the vm world of diff.
