Harry Balzonya
- Nov 12, 2004
- corner brook,nf canada
- www.poppaduff.piczo.com
richierich
the taper goes down
richierich
so it would be your second pic
Harry Balzonya
- Nov 12, 2004
thanks u know alot of people wonder that,
I wonder if Mr.sled would sticky that for a while.
ur 100% sure right
again thanks
jamie
ur 100% sure right
again thanks
jamie
richierich
yep 100% sure.i dont post info if i'm uncertain
easy way to remember is td=taper down.or if you just look at the angle and put the angle down.
i know what you mean though on my 1st one long time ago i was like crap what way and luckly i had a service manual to double check.
easy way to remember is td=taper down.or if you just look at the angle and put the angle down.i know what you mean though on my 1st one long time ago i was like crap what way and luckly i had a service manual to double check.
I asked the same question, taper down to clear piston I believe.
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
The taper is down to be flush with the exhaust port.
Rich, 2000 and others are right (of course) but just to make sure for the casual reader . . .
The first pic is the side that goes up. Rich indicated the second pic, but I think he meant that side goes down.
Harry Balzonya
- Nov 12, 2004
I give up on looking for it, had to buy it would You belive they cost $18 can.
When i Checked on my order the other day they said it wouldnt be in unntil the end of Feb Probably, but i could get it the next day for an extra $10..dummy me i did it of course just because i really needed it fast.
i kind of know already that i got ripped off.
yamaholic22
yup as 2000srx said the bevel goes down to sit flush with the top of the exhaust port (smooth exit for the gases)
