1994 vmax electric start
cougar1985
sault ste marie ontario
vmax 600 has self centering switch all ready . what is needed to put elct start in? does it allready have the ring gear?? i think it is the modle 600 ue if im not mistaken.sin is 8cfoo2373 model vx6 on ownership. :yam: :die:
The 94-96 Max's use a ring gear on the mag flywheel not the primary clutch. You will most likely need a flywheel. The engines were not bulid with the ring gear on them unless the machine it was going into was equiped with elec start.
You will need a battery mounting tray and the starter wiring inc a solenoid. The ignition switch is prewired.
