fastassyamaha
can i run a 1.5 inch on my 97 vmax with out running into any problems if i do it im not gonna run studs soo i dont have to worry about that but what about the lug hight is it alright with stock setup
Pull the tunnel and heat exchanger protectors if they are in there. Otherwise it's a bolt in and go sort of deal.
I second what ryan said, i have a 1.5 on mine, just pull both the tunnel protectors and the front heat exchanger protectors.
yamaholic22
I concur
..SNAKEBIT..
ME TOO
136 x 1-1/2
136 x 1-1/2
yamaha98sx700
What if you want to run studs?
woofer700
you will chew up your tunnel, with studs.
yamaha98sx700
Thats what I thought. I am looking for a good deal on a 1" preditor and would like to stud it later. Is there enough clearance for the front protectors and the tunnel protectors wit the 1"?
