ReaperSRX
I picked up a wide kit for my SRX and it comes with bushings to extend my sway bar, but i have a friend who has a sway bar from an Viper, would it fit.........Reaper
The sway bars are the same diameter. The Viper is 14mm wider(total length) then the SRX. I don't know if that would be enough for what you want to do, but those are the specs on them.
ReaperSRX
I don't think that will do, the MaxPerf kit i got gives me 1.25", the aluminum busings to go on the stock sway bar are much more than 14mm, thanks anyway for the info........Reaper
