VMax primary same as SRX?
700
Big Falls,MN
I'm wondering if a 95 Vmax Primary clutch is the same as the 98 SRX700? What models used the same clutch? Thanks, 700
Thanks Shortstop
I just need the movable sheave so can anyone tell me if that's the same? 700
i think they are the same but if you are getting one you might want to get one from a 2000 and up sled, they made the sheaves thicker so they aren't as likely to crack from heat, which is a problem on the yxr's.
