Heavy Hittters in SRX
nysrx
New York
How does the HH's perform in an SRX Any one have any good set ups to use with Heavy Hitters in an SRX. What is the difference between the stock HH's and the Viper HH's
I have the wieghts in a modded sx. I really like the weight. Its got a polaris type profile on it. The are really smooth on power delievery with out running your sled against a common friend or a clock I can see why some one would say they are the same. I have a setup a guy give me for an srx that I can send you. email me..
I run HH in my SRX and love the performance. I've run a Bender kit, Heelclickers, and Heavy Hitters, and out of the three I prefer the HH by far. The HC were a good weight also, but I struggled to get as much top end out of them as I do with the HH. As far as a good setup, I run a 54/46 Dalton helix, Maxx perf purple primary spring and green secondary spring wrapped at about 70. The sled pulls hard all the way through top end. Run lots of tip weight with some in the middle hole. I have my engagement right around 4000rpm and peak rpms are about 8200rpm slowly climbing to 8400rpm. Hope this gets you at least a starting point!
My buddy has my sled up north and I can not remember what I ended up with the hyperlite. I'll post it next week.
Here iis my old setup. I have a 700 with bender pipes, porting and other things.
Primary-51.5 base weight, 2.1 in #1, .9 in #2, 4.6 in #3 with 14.5 rollers and a blue hc spring (190/300).
Secondary-Maxx roller 41/35 with a green secondary spring.
SRX via buster (mega powe trail setup)-2.1gr 1/2" socket, 3.7 in middle, 3.4 tip. Maxx purple spring, 54/46 yamaha green wrapped to 90'.
