Exciter
Anyone knows if a ZR track (307*38*32) from -94 will fit the drive wheels on a -91 Exciter 2? Also, will the 1,25" lug height fit in the tunnel?
Thanks!
Thanks!
Mtnviper
The drive wheel/sprocket spacing is the same. The cross shaft that the two small idler wheels mount to will need to be dropped down, for clearance at the upper heat exchangers. Easy to do, just drill a couple of holes in the tunnel about 3/4" (measured center to center) below the original holes. Clearance at the front heat exchanger could be a problem though, it's pretty tight in there. Its best to mearsure the clearance with your old track then see how far you can go from there. If more clearance is needed, you can go with 7 tooth drivers.
