ekimsx600
Not to happy with my current set up. What are you running in you single piped sxr700?
4.5 gram inner & outer rivet with a 51/43 is about as good as it gets for a 112 hp 520 pound sled!
what fly weights turk?
That is with the stock 8df weights on a 00-02 700 sx-r.
what about a 97 sx 700? will 8DN-20 weights and a 51/43 helix with green secondary set at 70 work? if so, what kind of rivets in the tip.
ekimsx600 has a 99 sx700 he just found some 700 cylinders swap from a 600
ekimsx600
I swapped the whole motor.
ekimsx600 said:I swapped the whole motor.![]()
now we would have a fair race, i bought the 97 sx700. you still runing the 600 cdi box or did you acquire a 700 box?
ekimsx600
I bought a cdi from a 700.
