mxracer932
- Feb 11, 2006
I cant quite figure out why the temp icon on the lcd and the warning light on my 02 viper are flashing. It only flashes once in awhile but when it does come on it usually flashes in patterns of 6. I have tested the temp sensor on the top of the motor, replaced the thermostat, even pulled apart the water pump to check the impeller, and bled out the system (following the correct procedure). I live in the UP where there is plenty of snow on the trails and have never had a problem with overheating in the past so a rear heat exchanger is not necessary. The sled does not appear to be overheating as the heat exchangers are warm as though it is circulating. I brought it to the local yamaha dealer and they said there was nothing wrong with the cooling system and they couldnt get the lights to flash. I took it for a long ride after picking it up from the shop went over a snowbank and the lights began to flash again. Electrical short? The sled only has 1500 miles on it.. Where should i start looking? Anyone have this problem before?
