99 SX no head light or dash
T.S.U.Filmz
Lansing Mi
im have a 99 SX 600 triple and and none of the lights are geting power. The rpm gauge is broken it is not reading and gas gauge also. what could be causing this?
Jeff
high country said:
check the smoothing condenser, mine had the same problems and that was the culprit
Could you tell me where that is? I am having a problem with my 00 sxr. I think it could be the wire harness under the engine chafing.
i found the problem it was shorting out. my bro put a barriser on the sled and pintched them and they were shorting out. Thank you
Jeff
The smoothing condersor is a cylinrical electrical device by the headlights. I would say its about 1.5" diameter by 3-4" long.
