SRX01
WHAT IS THE BIGGEST PADDLE THAT I CAN STUD AND PUT ON AN 01 SRX. I DO RIDE BUMPY TRAILS AND JUMP SO I WANT TO MAKE SURE CLEARANCE IS SUFFICIENT. THE SUSPENSION IS STOCK WITH A LONG TRAVEL KIT.
without changing the drivers a 1" is about it....if you change the drivers to 8 tooth then you can go with a 1 1/4" and still keep the protectors and stud the sled.
