I have a2004 viper s .I have slp pipes,max. cluth kit,144 studs in 1.250 ripsaw with 8 tooth drivers .We are close out of the hole but the longer the run the more the 2005 800 H O rev pulls on me.What else do I need to do to stay ahead of it?
The ripsaw and 8 tooth drivers are probably slowing you down. Not sure what else you can do to stay ahead. Is the rev stock?
nodoo_s
did you change your gearing when you went to 8 tooth drives?
quebec#1
I agree the 8 tooth drivers and the 144 studs kills a little on top end.kinger said:The ripsaw and 8 tooth drivers are probably slowing you down. Not sure what else you can do to stay ahead. Is the rev stock?
Rev has a clutch kit and chrome rings.I know the 8 tooth drivers are hurting top speed,it run real free with 9 tooth drivers and no studs.Yes I changed gearing when Iwent to the 8 tooth drivers.I guess just run it til I need a new track then put 1" track on it with 9 tooth drivers, Thanks for the help.
