Who Has a Heel Clicker Clutch Kit?
MaximaFan
Any guys out there with this kit, let me know what you think, I might go with this one.
J.T.
heal clickers
Ive got them think they work pretty good, took me awhile to get them setup right but thats all part of playing.
I have a set on my mmax and they work great the only thing I don't
like is the top end falls off and I have not been able to find out why I
tried everyhting
Try taking some weight out of the tip so you can keep the rpm at the top
If the tip is allready empty you have 2 options. Get a helix with a shallower finish angle or even taking weight out of the heel will bring back top speed rpm,s.
I have the same problem with the sled going flat on the big end. The RPM's seem to hold all the way. Running a 46/36 Dalton, so I have a low finish angle. I am running a machined fixed sheave on the primary. Dony know if this is part of the problem. I know Jeff Simon is running HH now instead of HC. If I ever get it right, it will be a great setup, because it is stout on the bottom to around 95 - 100 MPH.
I have tried taking weight out of tip and didn't work I'll have to try taking
the weight out of the heel never heard that one. but well try anthing
I run a team secondary with a 56/38. I want to try a 54/36 If I can find
one to try
How do the heavy hitters work in the grass drags???
Yamageek what is your sled and what year and how many miles are on it
Brad
IT's a 97 mmax with slp old style pipes, ported, peak head, bored carbs,
boost bottle, comet primary, team secondary, 151 track, weights in at 480 lbs weight.
the sled runs great just looking for more topend in the grassdrags
I can run with 800,900 but they just get me at the end of the track
thanks for the help :rockon:
