archer
SRX startup lights
Does anyone know how long of a delay there is after the motor fires until the load relay closes? After my 3rd time fixing the wiring harnesses I only see my temp light blink once but I think that it has gone through the 3 blink cycle but doesnt have power to it until the 3rd blink. Wiring problem this weekend appeared as temp light coming on after a very rough section of trail. I determined temp was OK and coolant was circulating so I rode the ditches home and pulled, inspected, and repaired all engine compartment wire groups. Temp light doesnt come on except at startup and motor seems to run OK (if 110mph indicated sounds OK). Orginal wire rub-through 2 months ago was 2 of 3 white wires from mag to regulator shorted together. I forgot to measure V output from stator yesterday. Could stator be damaged? Lights, grips, tach, tail/brake lite all work fine.
Any ideas?
Doug
Any ideas?
Doug
