hereismylife
Who can tell me what the front (ground to bumber) hight should be.
I think mine is 2 inches to low?
thanks joe
thanks joe
SWEDE
Its all off of the rear control rods with you seated on the sled.You should have 50-50 gap top and bottom or 70-30 will give you less kick back when riding agressively,hope this helps.
hereismylife
thanks but I need to know the front in inches where the factory setting should be.
I think my shocks are weak in the front.
thanks joe
thanks joe
SWEDE
Not sure about your front,check the technical section.
Hey, joe i see you got your new ride,check here for some help,it goes by your front spring rate http://hem.passagen.se/rogg/yamsetup/startsida_eng.htm
shocks dont hold the sled up , the springs do
01sxr700
Shocks help hold up the front end as they r charged with 250 lbs of nitrogen.
