mbviperboy
do i need to run egt's with the bender triple kit?  i have the rear heat exchanger and the head gasket.
			Almost700
I have one on my 780 and they are absolutely worth while.  Just for the peace of mind in knowing that you don't have to worry.  Just glance down every now and then and your good.  If you don't, just be sure to stay away from mid throttle steady long runs.  They heat up in a hurry that way.  If you stay in the throttle(blip it alot) you will be ok.  If you can afford the coin for the egt buy one.  Face it, when you done with it you can sell it for darn near what you paid for it.
