Honing nicasil cylinders & jetting a ported one
fourbarrel
VIP Lifetime Member
I'm in the midst of the teardown from my weekend meltdown and found that the cylinder that has the melted piston is not salvageable so I'm at a crossroads here as to what to do.I've got a ported cylinder that was removed last year for a stock one and I'm contemplating putting it back on to save myself unnecessary down time and expence but I've no idea whos porting it is.There was 2 ported cylinders on this engine when I bought it but I didn't know it until I tore it down to replace a melted mag side piston in a previously new cylinder that got scratched.I replaced the 2 ported ones with standard ones to make all 3 stock but now to save myself $ I think I'll put it back on.This will make for 2 stock ones and 1 ported one so I'm not sure this will be the smartest thing to do but coin is a bit tight right now.
I've never "knowingly" run a ported engine so what is the rule of thumb for jetting the carbs anyway?Unless I can find someone who would like to trade for 2 ported cylinders for a 98/99 SRX 700 I'll be running one and as I stated I've no idea who did the work as they were on the engine when I bought it from a wrecked sled.
The second thing I would like some info on is honing nicasil cylinders;what should I use to take the glaze off and how should it be done properly?Take into consideration I've never done this myself but am not a total idiot when it comes to engine work as I have redone several 2 strokes before but all the cylinders I've had to replace were replated ones.I did try to find this info by searching for it but didn't find what I was looking for.Thanks. :rocks:
