srx600
has anyone put aaen srx pipes on their srx? if so how did you make out with them?
			snowprophet1
I heard that on a 700 SRX, the AAEN pipes are not as good as they are advertised to be.  On the 700 motor, you have to take your stock exh manifolds off, and use their manifolds, which are a sealing ring type.  The stock manifolds are a flared fit.  I happen to have a set of AAEN srx big bore pipes which are different.  These big bore pipes fit right against your stock exh manifolds and actually run better on a stock SRX than the regular AAEN srx pipes do from what I'm told.  I don't know anything about AAEN's on a 600 SRX though.
			srx600
pipes
I am asking because i bought a new srx and it has aaens already on it
