Both clutches work well. I've used them all, all, the yamaha clutch will out last anything but a TRA except the yammie is much easier to tune. The TRA's only issue is it's heavy and you have to learn how to shape ramps. The only trade off betwwen the P85 and the Yammie is you can move the spider on the P85, but you can change the roller size on the Yammie, does the same thing. The benefit of the Yammie is you can use ANY weight in it and change the rollers. The P85 will wear out buttons much faster than the Yammie, and if you've exploded a Yammie clutch, its because you were slipping the belt, got it hot, and it grenaded. P85's do the same thing.
For a 700 sx with pipes at sea level you could run 10 AL's with a 120/310 spring and a 48-42 in the back. 8800 rpms
