gearing+ clutching vmax 600
Busted Max
Edmonton, Alberta
i have a 95 vmax 600
i have a 136" x 2" track, 8 tooth extroverts and a dropped skid. the motor and pipes are stock.
it has a comet primary. i will be using the atacc system.
do any of you have any gearing and clutching help i could use. i will be riding valemount area.
thanks.
I have a couple of those. I have a pink pink pink primary with 89L and no rivets. Green sec, with 47 degree helix, 20 40 gears. For a 6 it rips pretty hard. My fav is the xt model.
thanks!
i like the xt too but i also like the 136x2" under it so i put the xt shocks on my ST.
will that work for the comet primary? it had a mtn setup in it before with the stock clutch but the weight snapped and put itself thru the sheave.
I don't think so. I have a friend that use to run a comet. I'll ask him what he used. He has since changed it though. He kept breaking the buttons about every 2 rides. He went to the p-85. The wt's I know are the a-2's. I'll see what spring he was running. Mine are both 136x2. Custom built drop brackets. Approach angle corrected. That is when they started working alot better in the deep stuff.
