Clutch Spring Conversion 8BV to 8DF
ryanwillden
I need to know what spring to use with my new style yamaha clutch. I had the 8BV (Old Style MM700) and I bought a new style MM700 (2000 and newer) and don't know what spring I need. I had a White-Pink-White 30, 2.25, 103 spring on the old style. What do I need to replace it with to keep the setup the same?
White-Pink-White?
Check the tech page on the home page, it lists the the short and long springs and the specs on each, you will be able to cross reference the spring you need.
I checked that, I just don't know if the same spec'ed springs produce the same results for the different clutch covers??? Can you answer that?
