yamaha big 4
anyone know if a set of srx tripples of any brand will fit in an viper chassis thanks for any info guys
sniperviper
They will fit but you have to do alot of mods on the pipes. Think I'v read somplace on this forum that "betheviper" has done this. Also think you will need a cdi unit from srx 2001-02..
betheviper and vipertripplexxx have done this
sxviper32
i've got srx pipes if you need them. pm me if interested...
vipertripplexxx
Yea they will fit, with no mods to the pipes. just some mods to the can, and port extensions on the exhaust. I was thinking of making some port extensions to do this conversion, but would need $100 per set if you want them. The 2000 CDI box is just good insurance so you don't burn it up. You can run without it, and it will have to be rich, just like all of the aftermarket pipes are for vipers need fairly rich midrange jetting. I would recomend using the srx cdi, if mileage is a conceren. You will need to cut out the side panel above the right front shock tower.
yamaha big 4
thanks for your input guys as far as a cdi goes i am planning on useing one from a srx it is a viper chassis with a srx motor not sure how i am gonna wire it all together yet thought i would get a wire harnes from both a 02 viper and 02 srx and combine them that will be my next purchase thanks again guys
vipertripplexxx
Let us know if you need a hand, definetly use the srx pipes! I smoke my buddies 05 mxz 800, and we get the same mileage!
you can only run a 2001 srx box, the 2000 has the wrong connectors on it, and a 02 has dcs and more wires so it wont work either, a 2001 will plug right in.
yamaha big 4
thanks i did not know that will save me a lot of time and money
do a search on this site and yaminfo.com for srx pipes in a viper and srx piped viper
between the two sites there should be about pages on the subject.
ive done all the r and d, enjoy, my sled gets 14-15mpg and is 12lbs heavier.
ragerider
How would this work with my dcs viper 05 mtn could I use a cdi box from an 02 srx?
vipertripplexxx
OOp's yea what mrviper said, only the 2001 box will work on a 2002. Not sure about the 04-05's, with dcs. Someone would need the service manuals to compare the wiring diagrams.
