yamahaulinass
on my 98 srx 700 there are two knock out holes on the side of the speedo and the tach what are them for?what guages can you put there? also has any one had any trouble with there chain case coming out of adjustment>? mine has came out 2 times this year what can i do to fix this Thanks in advance, any commets welcome
yamahaulinass said:on my 98 srx 700 there are two knock out holes on the side of the speedo and the tach what are them for?what guages can you put there? also has any one had any trouble with there chain case coming out of adjustment>? mine has came out 2 times this year what can i do to fix this Thanks in advance, any commets welcome![]()
Hi and welcome..What do you mean coming out of ajustment...what is it
doing????
yamahaulinass
srx
the chain in the case comes lose and skips and i have to adjust it with the bolt and jam nut how tight should i tightin it? i heard finger tight then tighin the jam nut but that dont seem to work.
Yea thats the way it's done,,is the threads stripped a little??
yamahaulinass
no i dont think so!! ill have to check it
do you know anything about the two knock out holes for gauges on them what guages can i put in there? are they salty to buy?
yamahaulinass said:do you know anything about the two knock out holes
No sorry
yamahaulinass
ttt anyone know
yamahaulinass
any one know what gauges i can put in it
Those nock out holes are just for looks. You can put a temp or egt in them. But they are not there for anything specific. Maxdlx
