1998 MM 600 Secondary Spring Setting?
dustydawg
Grand Lake, CO
Can someone tell me what the correct spring setting is for a 98 Mountain Max 600? The machine was marked 6 - 2 by the last owner, I just wanted to be sure. I am running it at 9000 ft, I just replaced the primary spring with a G-P_G, and am running an aluminum rivet (.8 grams) on the inner holes and empty on the tips. I have not run the sled yet, just did the work last night and wanted to have the secondary set correctly before I headed out. The spring was pretty tight, I was wondering if it should be 6-1.
Thanks!
