srx pulls
02srx
pa
i have a 98 srx. with a 02 srx skid the sled pull to the right on a hole shot. every thing seems to be set ok anyone have any ideas thanks
Tighten up your left limiter strap in small increments until it pulls straight.
aweseome feeback.... I have that problem too, jsut thought it was me leaning one way or another. I will have to dial her in :o)
problem was, I always seemed to line up to my buddy on his left, then I would drift toward him and have to blip the throttle for some steering input.....
thanks
Ramb
What you are doing is slightly tilting your skid. If you play with it, she'll run dead straight. I had to master that technique with my 900 kitty, with the coupling blocks removed, wouldn't set the ski's down till about 85.
You only need very small adjustments.
:WayCool:
