Concept Carbon
Ok whats the easyiest way to remove your transfer rods i have the adjustable ones from royal distrubuting on a 97 sx700.
the reason for removal is, the previous owner put the plastic washers or spacers on backwards big on top small on bottom to iliminate transfer, i want the most transfer i can get, its just more fun.
should i remove the wheels or remove the bolts holding the suspention.
thanks Jay
thanks Jay
To just change washers, remove the bolt that holds the top half and bottom half together, then remove the bolt that goes through the rail on the bottom half. No need to remove the top. Maxdlx
Concept Carbon
maxdlx said:To just change washers, remove the bolt that holds the top half and bottom half together, then remove the bolt that goes through the rail on the bottom half. No need to remove the top. Maxdlx
thanks, but arnt the wheel sin the way
Nope you can do it with the wheels on. I've done it, but the wheels come off easy enough. Maxdlx
Concept Carbon
cool il check it out, i have the 121 track and i thought the rods went behind the wheels.
thanks jay
thanks jay
They do onm top,but you only neeed to remove the bottoms. Maxdlx
