hereismylife
I did do some searching on here for this but not an answer I need
I forgot to take pictures of this while tearing this apart....pita....
1. I am putting the gear case together and I have 2 little shims that are u shade and say 7/16. what do they do? I remember taking them off of the lower left back side bolt
2. which way do the gears go on ( numbers facing out or in against frame) ?
3. should there be a space(gap) on the bottom gear(track gear)? the gap I have is from the retaining bolt to the gear.If you push the gear on to the gear case then put the little spacer on there is a gap then the washer and bolt.gap is about 1/4-1/2 inch wide
thanks for any imput on this issue
joe
joe
Mabie this will help;
click on the link;
http://216.37.204.202/yamaha_oem/YamahaSnow.asp?Type=13&A=138&B=31
click on the link;
