Making a Sled Stand/Jack
dnale
South Lyon, Michigan
Ok, I'll be doing some track tension adjusting and what not. I want to make a stand to support the rear of the sled so I can run the sled on a stand.
Does anyone have any ideas on how I could make one? I'm not a metal worker. I was thinking of a section of 4x4 with braces on each side and a black iron pipe between them. I could use a wratchet/tie-down to hand the rear bumper off the pipe.
Good? Bad? Any idea how high I should make the pipe?
I made a couple using a 2"x8" board and a couple of heavy duty angle brackets. Just cut the board to the desired height, cut a second for the base (about 16") and use the angle bracket to attach to form a "T". Works great and is cheap!
I just use a 4x4 with two 16" pieces of 2x6 screwed to the bottom. It actually was my trailer stand but works better for the sled. I just stand behind the 4x4, lift the sled, and lean the 4x4 in with my knee, easy and cheap.
take a piece of square thin piece of metal (for use as a base) and then weld some kind of metal rod or pipe (about 3 feet long) to it and then weld a big hook to it that looks like the j on your keyboard and then all you have to do is lift the sleds back end up and put the rear bumper on the hook and it will hold it right up if you want give me your email and i will send you a pic of it tommorrow by itself and one of it holding up a sled
Here's a pic of our stand, we got it from a neighbor, works pretty good and you don't even have to pick the sled up. We also just use jack stands to.
alright, these are some good ideas.
I'm not a welder and don't have access to one, so welding one up is out.
The pvc looks interesting.... It's sturdy enough to hold the back of a heavy sled? How high will I need to make it? (Sled is up north and I'd like to have it done before I go up.)
